got APR chip yesterday...all i can say is weehaaa!!!!!!
got it installed at rapid parts in Monsey NY. my car is definatly much faster but when i punch it in first gear, it feels as if it goes back into stock mode at around 5k rpm for about a second and back into chip mode. I got the 93 oct. and stock flipswitch also with the antitheft. it only does this in first. you might think its the clutch slipping but i also just had an rs4 clutch put in about 1 month ago. overall im happy with it. if you guys could give me som info tia
Do a throttle body adaptation on a COLD motor
I had a similar problem (though it was in all gears, not just first) and it turned out to be from doing a throttle body adaptation (with a VAG tool) on a hot motor. Let it cool down completely and did it again, and the hesitation was gone.
before starting it for the first time i let it sit with the key on (car off)...
to let the throttle body align itself which is recomended for about three minutes. ill probably go to the dealer to run VAG for codes.
