gt3 brake caliper adapter question
i recently acquired a gt3 big brake kit but i was told it was for a coupe quattro. i need to know where i can find the carriers to mount these on a b5 s4. rotors are off the slk55 i believe.
Apple + Orange + Lemon mixed with a little Grape = ? Could be easy, could be impossible...
good luck none the less and let us know how it turns out. You may just have to start mounting stuff up and seeing how compatible it is. Not sure anyone has used that exact setup before.
Re: Which Gt3 caliper, Mk 1,2,3....
unsure. he bougth it new about 3 years ago. i can post pics tomorrow if that help. all i know now is its a slk55 rotor with a 6 piston gt3 caliper. i traded it out for some tile work so either way im golden. if it dont/wont work i'll sell it.
That caliper usually runs on a 350 mm rotor, ceramic or steel. Does the
MBZ rotor fit with the correct offset? I would not trust that particular rotor with the clamping ability /heat generating six piston monoblock.
Try www.vehiclecraft.com if they would be remotely interested in making adapters / hubs w rotors for you.
Re: That caliper usually runs on a 350 mm rotor, ceramic or steel. Does the
the rotors are cryo treated. the offset is a bolt on to the ur quattro that my other friend put on his so i dont know if thats the same. it may be easier to sell these and buy a kit for mine.
