Has anyone had trouble with 1st gear grinding when downshifting? Not high rpm stuff just (more)
2 words; "Double Clutch"
First off, why are you using 1st gear except for from a dead stop? Just use second unless you are trying to slide the rear around. If you have to put it in first at those revs, no syncro will save you. Blip the throttle to get the input shaft up to about the right speed and then put it in gear gently.
Todd W
Todd W
There is a syncro, but only good for going into first from a stop
The syncro is only there so that you can idle in neutral at a light and then put it in first without waiting for the input shaft to spin down. First gear is too low for the syncro to be effective if the car is moving with any speed.
Todd W
Todd W
