Help with after run pump temp switch removal. Switch
turnsaround 360 (once clip removed)but will not come out. Don't want to twist too hard in case switch breaks off! Any ideas on removal?
should pop out if you have the clip out, sounds like the o ring is sticking.
maybe get a small screwdriver and try to work it loose.. GET AN EXTRA O RING incase you bust the original one.
keep the plug on so you have something extra to grip on...just shake it back n forth...
it should eventually just pop out. make sure the car isn't hot or you'll be sorry. If it is then wait for it to cool off a bit and uncap coolant reservoir to release any pressure inside the system.
quattro20v
Audi Original "S" Cars
08-05-2004 04:45 AM
