Help! Can not open the foglight relay...don't want to use any force
Old 09-22-2001, 11:48 AM
New Member
mys4avant's Avatar
Old 09-22-2001, 11:53 AM
dpd
Junior Member
dpd's Avatar
Default Re: Help! Can not open the foglight relay...don't want to use any force
why do you want to open it up?cover should pop off with a little finese
Old 09-22-2001, 04:41 PM
New Member
baldeep's Avatar
Doing the wiring on the outside is risky--better to open the thing up.
Old 09-22-2001, 06:54 PM
New Member
Neutron's Avatar
Default It takes three hands...
You gotta use a couple of jeweler's screwdrivers or the like to gently pry the edges of the cover away from those little tabs. I used two at once on one end of the module, worked the cover loose, then it popped off the tabs at the other end.
It's not difficult, but too much force -will- crack the cover. Ask me how I know that. It's hardly the end of the world, though... and once it's cracked, it basically falls off, so problem solved.
TimM is right, you don't -have- to open it up... but it makes for a much neater job with little to no chance of shorting anything, if you're even slightly skilled at soldering. If you solder across the lugs on the outside, the relay won't fully seat into its socket anymore.
Old 09-23-2001, 06:47 AM
JLoft's Avatar
Use single-edge razor blades to hold one side open while you are doing the other.
miaggi2
A6 (C7 Platform) Discussion
14
06-10-2015 02:26 PM
Zachary447
01-17-2013 08:09 PM
94LSC
Audi Original "S" Cars
10-08-2007 08:15 PM
south-side-niner-fan
07-18-2005 08:37 AM
Quick Reply: Help! Can not open the foglight relay...don't want to use any force
