HELP! Can't unscrew the outter tie rod from inner tie rod. Any tricks I am missing?
Doing the tie rod replacing now, but can't get the outter tie rod out. Seems like the whole tie rod is turning. Anything I am missing? TIA
powa ! lol.. it can be really frozen there , pray some wd40 or liquid wrench ..
and let is sit for a bit ..don't be afraid to use your "guns" ;p
and don't forget to put some antiseize on the new ones .
I told you earlier this week I had that same problem. The shop I took it to used a blowtorch. I
suggest you do the same if you're comfortable with that.
Have you gotton the lock nut (the thing right in between the tie rod end and the "inner tie rod") loose?
