HELP PLEASE ......s4 cranks but won't start
car has been sitting for 3 years the battery died and I replaced it with a non factory battery - the key fob was not working so I also replaced the batteries in it ....cant find the other key fob I only have one ......
please advise.... |
HERE ARE MY DTC'S
Chassis Type: 8D - Audi A4/S4/RS4 B5 (1995 > 2002) Scan: 01 02 03 08 15 16 17 25 35 37 45 55 56 57 67 75 76 77 ------------------------------------------------------------------------------- Address 01: Engine Labels: 078-907-551-AZA.lbl Part No: 8D0 907 551 A Component: 2.7l V6/5VT G 0003 Coding: 06611 Shop #: WSC 06325 VCID: 2842EC3CC808CE06F9-5140 6 Faults Found: 18014 - Rough Road/Engine Torque Signal from ABS P1606 - 35-10 - Electrical Malfunction - Intermittent 17861 - Exhaust Gas Temp Sensor 1 (G235) P1453 - 35-10 - Open or Short to Plus - Intermittent 17865 - Exhaust Gas Temp Sensor 2 (G236) P1457 - 35-10 - Open or Short to Plus - Intermittent 17521 - Oxygen (Lambda) Sensor; B1 S1 P1113 - 35-10 - Internal Resistance too High - Intermittent 18010 - Power Supply Terminal 30 P1602 - 35-10 - Voltage too Low - Intermittent 17834 - EVAP Purge Valve (N80) P1426 - 35-10 - Open Circuit - Intermittent Readiness: 0000 0000 ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: 8D0-820-043-1D.lbl Part No: 8D0 820 043 P Component: A4 KLIMAAUTOMAT D58 Coding: 00160 Shop #: WSC 26131 VCID: 2D4C1D28E7EAEB2E0A-2580 1 Fault Found: 01206 - Signal for Duration of Ignition Off Time 27-10 - Implausible Signal - Intermittent ------------------------------------------------------------------------------- Address 15: Airbags Labels: 8D0-959-655-AI8.lbl Part No: 8D0 959 655 G Component: Airbag Front+Kopf 1002 Coding: 00304 Shop #: WSC 06325 VCID: 3A66267426A44C969F-5140 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments Labels: 8D0-920-xxx-17.lbl Part No: 8D0 920 980 D Component: B5-KOMBIINSTR. VDO D09 Coding: 02264 Shop #: WSC 00000 VCID: 2C4A102CDCF0E2261D-5140 1 Fault Found: 00771 - Fuel Level Sensor (G) 30-00 - Open or Short to Plus ------------------------------------------------------------------------------- Address 35: Centr. Locks Labels:. 8D0-862-257.lbl Part No: 8L0 862 257 N Component: CV-Pump, Alarm, RC D16 Coding: 16200 Shop #: WSC 00000 VCID: 4092549C40781646D1-5140 4 Faults Found: 01367 - Central Locking Pump Run Time Exceeded (Likely Leak) 35-00 - - 01371 - Alarm triggered by Door Contact Switch; Driver's Side 35-00 - - 01370 - Alarm triggered by Interior Monitoring 35-00 - - 00956 - Key 2 09-00 - Adaptation Limit Surpassed ------------------------------------------------------------------------------- Address 37: Navigation Labels: 4B0-919-887-BNS3.lbl Part No: 4B0 919 887 A Component: Navigation 0001 VCID: 31740158FBD28FCE2E-4B00 1 Fault Found: 65535 - Internal Control Module Memory Error 00-00 - - ------------------------------------------------------------------------------- Address 45: Inter. Monitor Labels: 4B0-951-173.lbl Part No: 4B0 951 173 Component: Innenraumueberw. D03 Coding: 00101 Shop #: WSC 06325 VCID: 60D2B41CE0B87646F1-4B00 2 Faults Found: 01382 - Alarm triggered by Anti-Theft Sensor; Front Left 35-00 - - 01383 - Alarm triggered by Anti-Theft Sensor; Front Right 35-00 - - ------------------------------------------------------------------------------- Address 55: Headlight Range Labels: 4B0-907-357-AUT.lbl Part No: 4B0 907 357 Component: LEUCHTWEITEREGLER D003 Coding: 00012 Shop #: WSC 06325 VCID: 65DCA508FF9A136E02-5140 1 Fault Found: 01538 - Motors for Headlight Range Adjustment (V48) / (V49) 28-00 - Short to Plus End-------------------------(Elapsed Time: 07:40)-------------------------- |
Clear the codes, then attempt to re-start the car. What codes return?
Where are you located? |
I cleared and retried two other times
2nd attempt: Wednesday,27,December,2017,17:49:10:64469 VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64 VCDS Version: 17.8.1.0 (x64) Data version: 20171130 DS276.6 Ross-Tech: Home Chassis Type: 8D - Audi A4/S4/RS4 B5 (1995 > 2002) Scan: 01 02 03 08 15 16 17 25 35 37 45 55 56 57 67 75 76 77 ------------------------------------------------------------------------------- Address 01: Engine Labels: 078-907-551-AZA.lbl Part No: 8D0 907 551 A Component: 2.7l V6/5VT G 0003 Coding: 06611 Shop #: WSC 06325 VCID: 2842EC3CC808CE06F9-5140 No fault code found. Readiness: 0110 0101 ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: 8D0-820-043-1D.lbl Part No: 8D0 820 043 P Component: A4 KLIMAAUTOMAT D58 Coding: 00160 Shop #: WSC 26131 VCID: 2D4C1D28E7EAEB2E0A-2580 1 Fault Found: 01206 - Signal for Duration of Ignition Off Time 27-10 - Implausible Signal - Intermittent ------------------------------------------------------------------------------- Address 15: Airbags Labels: 8D0-959-655-AI8.lbl Part No: 8D0 959 655 G Component: Airbag Front+Kopf 1002 Coding: 00304 Shop #: WSC 06325 VCID: 3A66267426A44C969F-5140 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments Labels: 8D0-920-xxx-17.lbl Part No: 8D0 920 980 D Component: B5-KOMBIINSTR. VDO D09 Coding: 02264 Shop #: WSC 00000 VCID: 2C4A102CDCF0E2261D-5140 1 Fault Found: 00771 - Fuel Level Sensor (G) 30-00 - Open or Short to Plus ------------------------------------------------------------------------------- Address 35: Centr. Locks Labels:. 8D0-862-257.lbl Part No: 8L0 862 257 N Component: CV-Pump, Alarm, RC D16 Coding: 16200 Shop #: WSC 00000 VCID: 4092549C40781646D1-5140 4 Faults Found: 01367 - Central Locking Pump Run Time Exceeded (Likely Leak) 35-00 - - 01371 - Alarm triggered by Door Contact Switch; Driver's Side 35-00 - - 01370 - Alarm triggered by Interior Monitoring 35-00 - - 00956 - Key 2 09-00 - Adaptation Limit Surpassed ------------------------------------------------------------------------------- Address 37: Navigation Labels: 4B0-919-887-BNS3.lbl Part No: 4B0 919 887 A Component: Navigation 0001 VCID: 31740158FBD28FCE2E-4B00 1 Fault Found: 65535 - Internal Control Module Memory Error 00-00 - - ------------------------------------------------------------------------------- Address 45: Inter. Monitor Labels: 4B0-951-173.lbl Part No: 4B0 951 173 Component: Innenraumueberw. D03 Coding: 00101 Shop #: WSC 06325 VCID: 60D2B41CE0B87646F1-4B00 2 Faults Found: 01382 - Alarm triggered by Anti-Theft Sensor; Front Left 35-00 - - 01383 - Alarm triggered by Anti-Theft Sensor; Front Right 35-00 - - ------------------------------------------------------------------------------- Address 55: Headlight Range Labels: 4B0-907-357-AUT.lbl Part No: 4B0 907 357 Component: LEUCHTWEITEREGLER D003 Coding: 00012 Shop #: WSC 06325 VCID: 65DCA508FF9A136E02-5140 1 Fault Found: 01538 - Motors for Headlight Range Adjustment (V48) / (V49) 28-00 - Short to Plus End-------------------------(Elapsed Time: 06:24)-------------------------- 3RD ATTEMPT: Saturday,06,January,2018,16:11:15:64469 VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64 VCDS Version: 17.8.1.0 (x64) Data version: 20171130 DS276.6 Ross-Tech: Home -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Chassis Type: 8D - Audi A4/S4/RS4 B5 (1995 > 2002) Scan: 01 02 03 08 15 16 17 25 35 37 45 55 56 57 67 75 76 77 ------------------------------------------------------------------------------- Address 01: Engine Labels: 078-907-551-AZA.lbl Part No: 8D0 907 551 A Component: 2.7l V6/5VT G 0003 Coding: 06611 Shop #: WSC 06325 VCID: 2842EC3CC808CE06F9-5140 1 Fault Found: 18010 - Power Supply Terminal 30 P1602 - 35-10 - Voltage too Low - Intermittent Readiness: 0110 0101 ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: 8D0-820-043-1D.lbl Part No: 8D0 820 043 P Component: A4 KLIMAAUTOMAT D58 Coding: 00160 Shop #: WSC 26131 VCID: 2D4C1D28E7EAEB2E0A-2580 No fault code found. ------------------------------------------------------------------------------- Address 15: Airbags Labels: 8D0-959-655-AI8.lbl Part No: 8D0 959 655 G Component: Airbag Front+Kopf 1002 Coding: 00304 Shop #: WSC 06325 VCID: 3A66267426A44C969F-5140 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments Labels: 8D0-920-xxx-17.lbl Part No: 8D0 920 980 D Component: B5-KOMBIINSTR. VDO D09 Coding: 02264 Shop #: WSC 00000 VCID: 2C4A102CDCF0E2261D-5140 1 Fault Found: 00771 - Fuel Level Sensor (G) 30-00 - Open or Short to Plus ------------------------------------------------------------------------------- Address 35: Centr. Locks Labels:. 8D0-862-257.lbl Part No: 8L0 862 257 N Component: CV-Pump, Alarm, RC D16 Coding: 16200 Shop #: WSC 00000 VCID: 4092549C40781646D1-5140 4 Faults Found: 01367 - Central Locking Pump Run Time Exceeded (Likely Leak) 35-00 - - 01371 - Alarm triggered by Door Contact Switch; Driver's Side 35-00 - - 01370 - Alarm triggered by Interior Monitoring 35-00 - - 00956 - Key 2 09-00 - Adaptation Limit Surpassed ------------------------------------------------------------------------------- Address 37: Navigation Labels: 4B0-919-887-BNS3.lbl Part No: 4B0 919 887 A Component: Navigation 0001 VCID: 31740158FBD28FCE2E-4B00 1 Fault Found: 65535 - Internal Control Module Memory Error 00-00 - - ------------------------------------------------------------------------------- Address 45: Inter. Monitor Labels: 4B0-951-173.lbl Part No: 4B0 951 173 Component: Innenraumueberw. D03 Coding: 00101 Shop #: WSC 06325 VCID: 60D2B41CE0B87646F1-4B00 2 Faults Found: 01382 - Alarm triggered by Anti-Theft Sensor; Front Left 35-00 - - 01383 - Alarm triggered by Anti-Theft Sensor; Front Right 35-00 - - ------------------------------------------------------------------------------- Address 55: Headlight Range Labels: 4B0-907-357-AUT.lbl Part No: 4B0 907 357 Component: LEUCHTWEITEREGLER D003 Coding: 00012 Shop #: WSC 06325 VCID: 65DCA508FF9A136E02-5140 1 Fault Found: 01538 - Motors for Headlight Range Adjustment (V48) / (V49) 28-00 - Short to Plus End-------------------------(Elapsed Time: 34:49)-------------------------- |
No "engine" codes are being shown. The low battery voltage is typical for battery on/off/jumpstarting
Back to basics for troubleshooting since there are no codes. Fuel up to the rail? Spark from coil packs? (could be anything including crank sensor, oil sensor, etc) Or, reallly back to basics, is the timing belt actually intact? What do the plugs look like? Was the motor ever out of the car? (loose ground?) |
Back to basics is right ,....looking into fuel, spark, air.
but the engine has never been out ... It does have the giac chip though ? will that screw things up . I've re-seated it with no results .. the fuel level sensor is sending a code and the gauge is showing empty with ten gallons inside. will that kill the start ? |
you should be able to hear the pump "prime" when the ignition is turned forward (right before the crank position)
Additionally, fuel should be present at the fuel rail. Crack open one of the lines after priming the pump and it should readily leak out. |
I tried Listening out for the pump while a friend turned the key to the on position and I couldn't hear anything I tried hitting the tank as well to get it going but nothing ...I really hope it's not the pump or the fuel level sensor like the VAG might suggest but I still haven't checked the fuel rail
The pump is easy to hear when the key is turned forward to "on".
Probably a dead fuel pump. No noise would confirm that. There is no code for a dead fuel pump. |
Originally Posted by EricVonHa
(Post 25097840)
Probably a dead fuel pump. No noise would confirm that. There is no code for a dead fuel pump. I'll research that this week and get into the fuel rail to see if the pump is sending any fuel ... next will be spark if all is good |
