hey guys, something is wrong with my car, please help. it all started after the timing belt
Old 12-04-2005, 12:58 PM
BlackS4tt (Josh)'s Avatar
Default hey guys, something is wrong with my car, please help. it all started after the timing belt
and water pump service. during this service, i also had the valve cover gaskets and the cam tensioner seals replaced. Standing in front of the car, with the car idling and the hood open, there is a clicking, pulsing, and fluttering sound. it sounds like it is coming from the drivers side, toward the front of the engine, but it is hard to tell. it almost sounds metallic. the car has just been much slower than before. not running as strong. i used to pull about 4-5 cars on my friends 350Z, and i barely pull 1/2 car now.
when the tech did the timing belt, he used a cam lock bar, so im not sure how the timing could have been thrown off, but thats the only thing i can think of. here is a graph of the timing, does this look normal?
<img src="http://i16.photobucket.com/albums/b2/blacks4tt/stockTiming.jpg" alt="Image hosted by Photobucket.com">
the best part is, the tech who did the job did it on the side. he works at a local dealer, and he wont answer my emails or phone calls...
im going to take the car to a mechanic my father has always used, see what he says about the sound...
thanks guys
Old 12-04-2005, 01:00 PM
JoeS4's Avatar
Default Dealers suck. Dealer techs also often suck. Never have a job that big done by someone with no
accountability. My advice is to ask on the regional forum for your part of the country for a good local, independent shop. Good luck.
Old 12-04-2005, 01:06 PM
Default yeah i know, ill never be doing anything like it again. i can take the car to champion motorsports..
its going to be $$, buti just want it fixed properly..
LaserAvantS4's Avatar
it maybe timming belt slips a few teeth because of not-to-spec tightening
Old 12-04-2005, 01:39 PM
Hal_TT::CBP's Avatar
Default Your timing looks decent and the noise you are hearing is the drivers cam gear/chain/actuator.
See if the rear pass side isn't making the same sound... although this may be a little difficult if you have DPs.
Old 12-04-2005, 01:53 PM
so if it is what youre saying, what needs to be done?
Old 12-04-2005, 01:54 PM
Default that sounds like a possibility... he didnt use a dial-in wrench to tighten...
the belt actually slips over the teeth?
Old 12-04-2005, 02:01 PM
Nigel (no more S4)'s Avatar
listen to S0NNY. Timing belts can skip a tooth, it's happened a number of times.
Old 12-04-2005, 02:17 PM
BLK01S4's Avatar
Say hi to my car when you are there LOL
dscottjr's Avatar
You should take it to Gus at Os performance.
Quick Reply: hey guys, something is wrong with my car, please help. it all started after the timing belt
