How do you recode your instrument cluster to have auto up windows with the remote?
And also how can I change what mpg my cluster says my car is getting? There is something in VAG com that allows you to modify it isn't there? I already STFA...
Thanks
Thanks
Read this all info inside.. ==>
35-Central Locks: -- KWP-1281
VAG-COM Works fine (note: pre-'97 A4's may not have this module).
Recode locking options
[Select]
[35 - Cent. Locks]
[Recode - 07]
Enter the coding below
[Do It!]
Write down the existing coding for future reference.
A4 pre-1998 with Delta radio and anti-theft system
Standard Coding: 03468
A4 pre-1998 with Delta radio, anti-theft system and keyless entry
Standard Coding: 12172
A4 1998+ with Concert/Symphony radio and anti-theft system
Standard Coding: 03340
S4, A4 1998+ with Concert/Symphony radio, anti-theft system and keyless entry
Standard Coding: 16140
Add the following options to your coding number:
+64 Windows up, sunroof close, and windows down with remote.
-04 One touch unlock of all 4 doors and trunk
-1024 Remove horn honk when arming
+32 Auto lock/unlock of doors (Doors lock at 15 mph and unlock when key is removed)
So, if you want to have a 1999 A4 with Concert radio and anti-theft system and keyless entry, and you want to add window control with the remote along with auto-lock, then:
add 03340+64+32= 03436
[Select]
[35 - Cent. Locks]
[Recode - 07]
[Do It!]
Right now it indicates a false mpg because of the stage 3 fueling. I seem...
to remember someone mentioning the ability to change the mpg reading by up to 20% or something. That would help. And I also remember people talking about being able to use the VAG com to enable your remote to put up and down the windows. There is a list of numbers that you add or subtract to the base number to make these remote mods....I just don't know what the numbers are or where to make the changes.
