how do you remove the auto leveling motor from the stock housings...
i installed my euros over the weekend. i tried to remove the auto leveling motor from my stock housings by pulling on it. i didnt see any screws or clips holding it in. i also didnt want to pull too hard so i wouldnt break it. so how exactly do you remove it?
Yeah. And rotate the pin toward the back of the housing as you pull. It also helps to move the hou
sing, that is where the light would be focused, in the all the way down position to reinsert. Just pry upwards lightly on the low beam bulb housing to do so.
AudiWorld Expert
adjust the white manual adjustment screws first - then see my website...
<img src="http://ctny.audiworld.com/mark/s4/euros/dsc01777.jpg">
<img src="http://ctny.audiworld.com/mark/s4/euros/dsc01699.jpg"><ul><li><a href="http://ctny.audiworld.com/mark/s4/euros/index2.html">http://ctny.audiworld.com/mark/s4/euros/index2.html</a</li></ul>
Turn highbeamlevel adjustment screw all the way CC. Then, pivot the motor housing 45 degrees up
from the bottom of the housing to unseat the plastic fasteners similar to the blinker light housing. When the motor housing is unseated, push the greenball to the bottom of the light housing throgh the slot in the housing and it pops free. Practice a similar procedure on the dummy plugs of the Euros to get familiar.
moses
08-09-2005 03:18 AM
RippleChip
04-09-2005 07:00 AM
shuto
01-01-2002 06:00 PM
