How many cam plugs do I need for a complete valve cover gasket job?
One head or two?
You only need valve cover gaskets (2) to do a valve cover gasket job. But if you are replacing other gaskets/seals, the heads take:
2 cam caps (1 per head)
4 cam seals (2 per head)
2 cam tensioner gasket SETs (1 per head)
Cam tensioner gasket sets include the metal gasket and the 1/2 moon seal.
-Dave Pramanik
-Dave Pramanik
thanks... still kinda confused. just to confirm...
Audi Vw Valve Cover Gasket Kit Includes:
2 Front camshaft seals (Improved 'Viton' seal material) == 2 of your "4 cam seals"?
2 Rear camshaft seals (Improved 'Viton' seal material) == 2 of your "4 cam seals"?
2 Rear camshaft end cap seals == "cam caps"?
2 perimeter Neoprene valve cover gaskets == in your "cam tensioner gasket SET"
2 center Neoprene valve cover gaskets == in your "cam tensioner gasket SET"
2 improved tensioner cam chain gaskets == in your "cam tensioner gasket SET"
2 improved camshaft valley seals == "1/2 moon seal"?<ul><li><a href="http://www.blauparts.com/proddetail.asp?prod=GF21002">so basically, all I need to buy are two of these puppies?</a></li></ul>
It looks like you just need one of those.
That kit looks like it contains everything for 2 heads.
<b>Correct. The "Front" and "Rear" cam seals are the same parts.</b>
<b>Correct. Although it is on the rear of one head and the front of the other so the "Rear" designation is a bit misleading.</b>
<b>No, these are the actual valve cover gaskets. I didn't list those out since I thought they were implied in a valve cover gasket change.</b>
<b>Correct.</b>
<b>Correct.</b>
-Dave Pramanik
<b>Correct.</b>
<b>Correct.</b>
-Dave Pramanik
David Steve Perez
18
10-30-2015 01:16 PM
audi49
02-11-2009 06:08 AM
Parts needed for cam seals? Getting ready to replace headcover gaskets and cam seals. When searching
Cooper993
9
12-13-2007 02:22 PM
Kep
06-08-2007 06:17 PM
