how much do you guys think I should ask for a MTM stg2+ (old stg3) chip only?
that and what are AWE center vent boost gauge's going for these days?
Oh and Sti's are fun ;-p
do the awe center vent boost gauge yourself, took me 10min to cut...
you know how pliars have that little slit in the beginning of them?
find a tool at the hardware store that is as small as possible that only has that blade. works perfectly to cut the plastic.
what i did to get the measurements was find the formula for a chord of a circle. measured the spacings between the vent blades to be 6mm, each blade is 2mm thick. just use the equation of the circle to get the proper marks, mark it. cut it.
measuring took me long, but cutting was easy. measure twice, cut once.
easy, looks just as good if not better. mine is so perfect i have a 1mm space at the top of the gauge, and 1mm at the bottom.
AudiSport44
12-21-2005 07:13 AM
BlackS4tt (Josh)
44
05-14-2004 10:32 PM
s54m3
Florida Discussion
10-21-2002 04:55 AM
