I/C mister question...
Anyone istalled the Labtronics intelligent I/C mister on a 01' S4? What injector you choose (color code) to connect the cable for duty cycle signal? I know Don P picked the brown/black wire in his writeup but his was a 00' S4. He also mentioned the wire color changed after 00'. Trying to save some time here. Thanks.
Re: You can look at the wires for any injector to get the color. Just verify with an ohm meter.
Thanks Don. A couple of quick questions: What size diodes did you use for the remote? I can only find some slightly larger than the originals (Radio Shack). Also I've seen a intermitent diode I'll like to get for the pump remote, however dunno if it will work. Also, can I place the remote diodes behind the fog/ESP switches since I don't have an empty switch(01' car)?
what don said. here's a pic to illustrate
i picked the front driver-side injector (not sure what # cylinder bank that is). use a flat head screwdriver to push the rubber boot back and you'll see the wires. that'll be the one you tap into @ the wiring harness
<img src="http://www.funkadelic.org/albums/ic_misters/aaj.jpg" border="1"><ul><li><a href="http://www.funkadelic.org/gallery/ic_misters">http://www.funkadelic.org/gallery/ic_misters</a</li></ul>
kalivornian
10-14-2005 04:58 PM
QuickSilver2
01-21-2005 07:33 PM
nightkrawler
07-27-2004 12:27 PM
lukin36
12-06-2002 03:52 PM
