I can just get spring with a stock suspension i wont need struts correct?
Old 04-23-2005, 12:36 PM
2000SForce's Avatar
Old 04-23-2005, 12:39 PM
sg_wannabe's Avatar
you can just swap out springs and keep your stock shocks, yes.
Old 04-23-2005, 12:46 PM
2000SForce's Avatar
thank you sir
Old 04-23-2005, 12:51 PM
TwinTurboTerror's Avatar
I would not recommend it though. The ride quality will be teh suck.
Old 04-23-2005, 12:52 PM
sg_wannabe's Avatar
Default BUT i recommend you do both at same time. what springs? and also, u installing or shop (more)?
as you know, with springs and shocks, you want them to match up.
with many springs (only), you will wear out your stock shocks quicker.
if you are installing, then i would say toss up b/t doing springs only now and doing springs and shocks.
if you are having shop do it, think of labor cost added when you have to go in and replace stock shocks.
i am not sure why you are doing springs only, but if it is a money issue, then i would say wait and get a good spring and shock matchup.
hth
take care.
Old 04-23-2005, 12:59 PM
2000SForce's Avatar
Yes its the money issue... i wuess i will wait and spend 300 more and go for the streetsports
Old 04-23-2005, 01:03 PM
corll_S4's Avatar
s4returns is exactly right, wait and get a matched set.
Old 04-23-2005, 01:10 PM
Junior Member
oldyellar's Avatar
Default in response to your earlier post......i have eibach's......
<center><img src="http://pictureposter.audiworld.com/71155/picture_010.jpg"></center><p>and I think its too low (24.5" fender lip to ground) but I run 245/35/18 without rolled fenders and no rubbing. Negative camber is major with this ride height though and its tough on front tires.
Old 04-23-2005, 01:11 PM
Junior Member
oldyellar's Avatar
good idea
Old 04-23-2005, 01:50 PM
Default 3rd. If you're having a shop do it, definitely save up for new shocks too. Otherwise you're just
throwing money away on the labor cost.
jlparrotte
03-31-2003 09:10 PM
hs601
03-26-2003 04:23 AM
sweeta4
08-28-2002 05:30 AM
GrantlyS4
01-15-2002 09:39 AM
2.7t john
06-20-2001 09:55 AM
Quick Reply: I can just get spring with a stock suspension i wont need struts correct?
