i do not like the neuspeed/borla tips....
The small tip inside keeps the outside tip from getting too hot and tarnishing...
AWE sells a Borla with those inner tips cut out. I have it and like it a lot, but the tips do tarnish after the heat generated by a track event. Furthermore, AWE cuts off both sets of tips and then rewelds the outer set to make these, so welding is obvious when looking at the tips, but you pretty much have to have the car up on a lift or be lying on the ground to see that enough for it to bother you.
I cut mine out with a dremel last week
Mine have turned a bit goldish already although I'm running a little rich right now and was running it hard yesterday. LCP is correct about the tip coloring. If you really care about the cosmetic look (color, shine) then I would not recommend it.<ul><li><a href="https://forums.audiworld.com/a4/msgs/561274.phtml">https://forums.audiworld.com/a4/msgs/561274.phtml</a</li></ul>
funkadelic
22
08-18-2001 12:25 AM
SDSilver01
06-02-2001 01:40 PM
NEED FOR SPEED
05-13-2001 10:09 AM
BIG NIPPER
04-18-2001 06:03 PM
