I get this short (less than a couple secs) grinding noise and slight pulse in the brake pedal when
Old 03-21-2008, 05:06 AM
Senior Member
a4tis™[Bye Turbo]'s Avatar
Default I get this short (less than a couple secs) grinding noise and slight pulse in the brake pedal when
braking - just before coming to a stop. Braking to reduce speed doesn't produce the same result; only when coming to a full stop. **edit*** the pulse is not continuous - it's just one short pulse.
Any ideas what this could be? I'm running stock HP2s and pads. Also stock rotors. Because I'm running stock rotors, my first thought was they're warped, but that would cause more pulsating and vibration IIRC. So I'm not too sure what this could be.
I'm pretty sure I didn't have this noise before I had my Autospeed DTS installaed, but I don't see how it could be related.
Old 03-21-2008, 05:35 AM
Bracketracer's Avatar
Default sigh...
And I sit here wondering if there is or was ever a completely trouble-free B5S4.
I'm wondering if one of the rear axle reluctor rings/tone wheels has a hairline crack in it. Unable to be picked up by VagCom, but usually able to be seen with a bit of disassembly.
Old 03-21-2008, 06:35 AM
exorcet's Avatar
Default re-bed the pads and see if that helps. are they new or old? maybe just worn - check rotor
and see if you can catch your fingernail on any grooves?
Old 03-21-2008, 07:04 AM
Senior Member
Default well I hope we can get a better idea when I drop by the shop on Monday
and my S4 is as trouble free as they come
Old 03-21-2008, 07:13 AM
Senior Member
ill see if i catch any grooves, thanks for the advice. brake pads arent that old
ppinto1
9
06-11-2018 06:27 AM
kap1
07-18-2006 01:15 PM
downindenver
Audi allroad
12-15-2005 08:12 AM
AW #29529
06-19-2002 08:24 PM
Audi_Sport
04-27-2001 01:09 PM
Quick Reply: I get this short (less than a couple secs) grinding noise and slight pulse in the brake pedal when
