i have a proble with my tranny and need to find out what it is.................
Old 04-15-2005, 07:04 AM
Member
S4orce2001's Avatar
Default i have a proble with my tranny and need to find out what it is.................
when the car is cold, meaning after not driving it for more than like 6 hours, when i jump in the ride and try to go ahead and put it in gear, it actually takes a while before i can put it in gear, any of them. now after driving it for a while, i would say a mile or two, it starts to be more smooth, after that no problem everything just fine, maybe a little hard but i beat the living crap out of my tranny.
now i thought it could be the master cylinder but im not sure and wanted to see if this has ever happend to someone in here.
TIA.
Gus
Old 04-15-2005, 07:15 AM
Pat-SoCal's Avatar
Definitely the "master cylinder"... you're screwed!
Old 04-15-2005, 07:27 AM
Member
S4orce2001's Avatar
but the car still driving fine. now how long can i go with it like that.
Old 04-15-2005, 07:31 AM
LCP
AudiWorld Expert
LCP's Avatar
Default BTDT...
...master and slave cylinder on the clutch was shot (as was the line between), but I also had a problem with coolant leaking through the bellhousing onto the flywheel and contaminating it -- that was very hard to diagnose and get fixed and there were many attempts and frustration.
Old 04-15-2005, 07:34 AM
LCP
AudiWorld Expert
LCP's Avatar
Default It will probably just get worse...
...I got where I would leave my car in 2nd gear pointing the direction I needed to be headed if I was going to park it for a while (i.e., back in when I parked, or if I had to pull in head first, made sure the way out of the parking spot was not uphill at all). That way I could still be mobile while either pressure built in the system or heat burned off some of the coolant contamination on the flywheel.
Old 04-15-2005, 07:37 AM
Member
S4orce2001's Avatar
what do you mean coolant contamination, and how does that happen
Old 04-15-2005, 07:38 AM
Member
S4orce2001's Avatar
coolant from where? and how did it get there.
Old 04-15-2005, 07:47 AM
LCP
AudiWorld Expert
LCP's Avatar
Default It leaks. There are holes and access points along the top of the bell housing.
<ul><li><a href="https://forums.audiworld.com/s4/msgs/1530867.phtml">https://forums.audiworld.com/s4/msgs/1530867.phtml</a</li></ul>
Old 04-15-2005, 08:05 AM
Member
S4orce2001's Avatar
so from that hose leaks into the tranny.
Old 04-15-2005, 08:22 AM
AntiSocial's Avatar
Ever change the gear oil?
Quick Reply: i have a proble with my tranny and need to find out what it is.................
