im having a little problem with my brakes. the brake pad light comes on and goes away, whats that?
Is it your brake pad warning light or the word "BRAKE" flashing in red?....
If it's the low brake pad indicator and you're using stock pads, you might just need new pads. If you're using aftermarket pads and have tricked the car by wiring the wear indiactor together, then you could just have a loose connection in your wiring down at the sensor location.
If it's the work "BRAKE" flashing in red, then it's something different.
Which thing is flashing?
That's good - you do not have issues with the ABS system or the fluid, IMO. I think you either.....
need new pads up front or have a problem with your splicing of the wear indicators (if you're not running pads with wear indicators)...
Do you have stock pads or other pads with wear indicator wiring?
