Innovate THIS:
Where/How should I mount this bad boy? Anyone have suggestions or pictures?
This Innovative wideband display: <img src="http://pictureposter.audiworld.com/90646/audi_innovate_install_1_001_small.jpg"> Needs to be seen in here: <img src="http://pictureposter.audiworld.com/90646/audi_innovate_install_1_003_small.jpg"> |
you should do like i did... out the glove box, the cord makes it sit very nicely
right infont of the quattro badge, then when you dont want to see it its painless to open the glovebox and it falls right in. you also dont have to make any holes in your dash. air fuel guages are so busy, especially at night. trust me you really dont want it in your direct line of site or even close to it and deffinatly not solid mounted there. when the glove box is closed it pinches the the wiers to the guage and it sits there perfectly.
need a pic? |
Steering column mount
I'm putting mine in my A-pillar along with my boost gauge...I'm going to make a power
switch for it so when I don't want to use it I'll turn it off. To fix that "busy" look like Jared mentioned below. I'd use his idea tho
definitely in the shift knob. definitely.
picture please
I was just gonna suggest that!
be careful...
make sure its just the guage that you power off and not the controler. if the controler is off and therefore the sensor is unpowered it will kill it. i made that mistake before and the sensors dont last long when in a running vehicle and unpowered. i went through three of them before i wised up and read into it. wouldnt you know that they actually tell you not to allow the sensor to be off in a running vehicle.
i felt like coming home anyway.
so here are a few and one final one from the drivers position at idle.
<img src="http://pictureposter.audiworld.com/108321/0830061509.jpg"> <img src="http://pictureposter.audiworld.com/108321/0830061510.jpg"> <img src="http://pictureposter.audiworld.com/108321/0830061510a.jpg"> <img src="http://pictureposter.audiworld.com/108321/0830061510b.jpg"> <img src="http://pictureposter.audiworld.com/108321/0830061514.jpg"> |
these guages are kinda big
