Just finished my Greddy Turbo Timer and boost/o2 gauges on my S4!
I was doing some tinckering the other night testing the wires leading out of the steering column and finally figured out how to wire the turbo timer. I wired the trigger to a switch so it only activates by flipping the switch instead of the using the ignition.
While running wiring for my Greddy boost gauge, I discovered the best place to run wires through the firewall is to just use the big 1.5" hole that is already there. Just remove the ECU lid under the hood and shine a flashlight into the harness hole and you will actually see your pedals! I ran all my boost gauge wiring through that hole. It's much easier than trying to go from the underside of the chassis!
I ended up putting my Autometer O2 gauge in the far right center vent. Made a small ABS trim plate and had a small LED indicator placed next to it.
If people are interested, I will get pics of the gauges installed. Everything looks very clean and is barely noticeable from stock. Also, there is no obstruction of any of the factory gauges.
When I took the car to the dealer, they didn't even notice till I mentioned it to them.
<a href="http://icdweb.cc.purdue.edu/~kor/audi_s4.htm">
<img SRC="http://icdweb.cc.purdue.edu/~kor/pics/s4sigpic.jpg" BORDER=0></a>
Felk_2.7T
01-16-2006 10:20 PM
does anyone know if there is a heads up boost gauge (like the DEFI) thats not a turbo timer as well?
liquidforce
10-22-2001 06:09 PM
Oettinger//S4
09-18-2001 11:25 PM
hater
08-07-2000 02:45 PM
