Just got turbos swapped....do I need to realign headlights with VAG ??? thanks!
VAG needed for Xenon adjustment...
If you simply adjust headlights and go beyond a relatively small adjustment range, I believe that you will soon get an alert on the dash indicating that the auto headlight trim system has malfunctioned, and a DTC from the headlight CPU (I did...).
It's pretty easy to clear the DTC and re-zero the auto trim system using VAG. Check the Bentley manual for the procedure.
I read somewhere here that you can fine trim the headlights using VAG as well, but this is not the procedure I used. I put the headlights into calibrate mode (no trim active), set the lights, then reactivated the auto trim. It seemed to adapt fine to the new position and I have not seen a DTC since!
Robert F
11-04-2008 07:04 AM
lemieux@curbside
14
10-12-2004 09:16 AM
S4Patrick
07-29-2003 01:22 PM
lawong
01-28-2003 07:38 AM
