Just making sure I have the MBC install correct...2 questions.
1.)Comparing the two pics below...is the "actual" pic of the MBC color coded correctly to the diagram?
2.)Adjusting the MBC, should it be completely closed (ordering one with bleed hole plugged) or completely open for the initial run?
If its completely open, it should just feel like it does without the MBC, correct? So from there I can tighten it until I reach the desired peak boost. Does that sound correct?
<img src="http://pictureposter.audiworld.com/47312/manualboostctrl.jpg">
<img src="http://pictureposter.audiworld.com/8894/mbc-color-coded.jpg">
Neon01
13
12-15-2003 07:46 PM
