Just ordered the three grills that are in the front bumber..Left Right and Center
Got them from clair, 56 dollars for everything. They come primed with the mesh behind them. I will proceed to make my bumper look like the RS4 front end. I think a little work to cut the divider out of the three parts shouldn't be too hard. Getting some new mesh should be easy enough. Will try and make a new grill for the hood also so they all match. Will keep you posted on the project to see how things go.<p>AutoThority Chip
19x8" Axis Se7en - Gun Metal
H&R CoilOvers 25" FR - 25.5 RR
UUC Short Shifter, Exhaust
Llumar Tint 35% - Metalized
Clear Corners
Red Calipers
Clear Corners
Red Calipers
Guest
Posts: n/a
Is this the look you are going for?
<center><img src="http://pictureposter.audiworld.com/AudiWorldPics/2000/S4_grillmod3.jpg"></center><p>If so, I can't wait to see it when you have it completed. Be sure to take good photos of the process! (BTW this pic is a photoshop job)
thanks seattle, I swa your posts yesterday, this is what I am going to do yes, man that looks good.
<p>AutoThority Chip
Clear Corners
Red Calipers
Clear Corners
Red Calipers
Here you go
<center><img src="http://pictureposter.audiworld.com/AudiWorldPics/2000/Red%20Caliper.jpg"></center><p><p>AutoThority Chip
Clear Corners
Red Calipers
Clear Corners
Red Calipers
Where did you find the grill pieces at clairparts.com?
<p>Scott G.
2000 Silver/Black S4 - Head on with Deer that likes Xenon's - Total Loss
2000 Silver/Black S4 #2 - Bridgestone Potenza S-02 Pole Positions -- To come: UUC SS, APR chip, UUC/MTM exhaust?
Clair has them but not on the website. $17.25ea l/r $21.00ctr
<p>AutoThority Chip
Clear Corners
Red Calipers
Clear Corners
Red Calipers
don't know if you have them or not but...
you'll see that the mesh section has tabs that were heat melted. these tabs are actually a part of the main mold. ask anotherdrew, he's already cut the mesh out of the left and right pieces.
the tricky part will be the center grill section b/c they too are heat melted on. you'd have to either cut those tabs from the front of the bumper (which is near impossible) or just take the whole bumper off to get to it. that center piece is probably going to be your worst enemy.
here's what i'd do, just as a start: get some black tape and put it on the middle slats. it'll at least give you idea of what the whole project will look like before you start actually cutting into the bumper piece. this mod isn't worth a whole bumper. i've already done some of this with the grills including the rs4 look and for some reason, i just like the plain s4 look better. if you actually look at the rs4, the vertical pieces underneath the plate are much more angular and wider. also, the left and right grills are set much deeper than the s4 hence, the rs4 look isn't quite there. the only thing that looks nicer is a different kind of mesh material behind the actual grill pieces.
good luck and tell us if you succeed in getting that middle piece out w/o removing the whole bumper.
Silver S4
24
07-17-2000 10:11 AM
Silver S4
15
07-13-2000 06:11 AM
Silver S4
06-02-2000 07:16 AM
Silver S4
06-01-2000 09:34 AM
Silver S4
9
05-15-2000 05:18 PM
