K04 Tiptronic (Transmission Cooler & RS4 Oil Cooler) *Mad Bandwidth*
Old 07-10-2004, 01:25 PM
BLK01S4's Avatar
Default K04 Tiptronic (Transmission Cooler & RS4 Oil Cooler) *Mad Bandwidth*
Got the car back on the weekend from D&N in Miami, they did a pretty top notch install had to customize a few things like the condensor fan n stuff overall I am pretty happy. The Trans cooler is a B&M unit (RACE) with custom made hydralic hoses THe fittings screw right into the factory lines. Comes from the Radiator into the cooler back to the tranny. I am going to collect some data soon (Before n After coolers) I also filled the car with Distilled water & Purple Ice see how that works out. On Monday the car will be going back for new Cam Seals, Timing Belt, Water pump, etc etc etc basicly Maint. Here are some pix of the install Enjoy!.
<img src="http://pictureposter.audiworld.com/52597/trans-oil-cooler1.jpg">
<img src="http://pictureposter.audiworld.com/52597/trans-oil-cooler2.jpg">
<img src="http://pictureposter.audiworld.com/52597/trans-oil-cooler3.jpg">
<img src="http://pictureposter.audiworld.com/52597/trans-oil-cooler4.jpg">
<img src="http://pictureposter.audiworld.com/52597/trans-oil-cooler5.jpg">
<img src="http://pictureposter.audiworld.com/52597/trans-oil-cooler6.jpg">
<img src="http://pictureposter.audiworld.com/52597/trans-oil-cooler7.jpg">
<img src="http://pictureposter.audiworld.com/52597/trans-oil-cooler8.jpg">
Old 07-10-2004, 01:41 PM
GeneMan88's Avatar
I didn't think a Tiptronic tranny could handle K04 power...
Old 07-10-2004, 01:45 PM
Elder Member
BiturboBoy_V2.0_S3--'s Avatar
he is the first Level 10 modified tip on AW.
Old 07-10-2004, 01:51 PM
GeneMan88's Avatar
Ah... level 10 would solve that problem indeed.
Old 07-10-2004, 01:57 PM
Guest
VR_Life's Avatar
Default Official Nomination : AW Trailblazer Hero Status ! (Please reply Ya / Nay ?)
Here's someone doing truly pioneering work (and not just larger impeller blades, scary boost pressures or bigger manifolds). If only we had a hall-of-fame page !
P.S. All that exposed piping on the under-belly of the car is VERY scary ! Please invest $50 in some covers - I want you to retain hero status ;-)
Old 07-10-2004, 01:58 PM
Junior Member
back2black's Avatar
very clean setup...
Old 07-10-2004, 02:21 PM
BLK01S4's Avatar
Default Re: Official Nomination : AW Trailblazer Hero Status ! (Please reply Ya / Nay ?)
haha ya going to lift that stuff up I removed the belly pan in the name of cooling =\ I am going to run some scary boost pressures though! =]
Old 07-10-2004, 03:35 PM
jonah's Avatar
aren't the cooling benefits of removing the pan in dispute?
Old 07-10-2004, 03:42 PM
Member
chuangs4's Avatar
Default Great infos, Michael!...
Thanks for sharing us.
However, do you think a custom tranny cooler is a "mustbe"? or just relocate the stock one?
Old 07-10-2004, 03:58 PM
AudiWorld Expert
nyet's Avatar
wow, nice work. btw. 2nd the notion that you might want to put the belly pan back on
Quick Reply: K04 Tiptronic (Transmission Cooler & RS4 Oil Cooler) *Mad Bandwidth*
