Little bit of a squaling noise from the front of the motor near the fan. 89K on the meter
All original parts in the motor to include timing belts and waterpump. THoughts?????
bad, bad thoughts . . . get it looked at tomorrow . . . catastrophic failure could total your car .
The pump bearing fails and chucks the roller bearings all over inside the timing cover. There was so much play in this "bearing" the impeller broke.
<img src="http://66.134.70.69/files/audi/streetwerke/hall%20of%20shame/water%20pump/water%20pump%202/IMG_0535.JPG">
This was just one of about 13 roller bearings collected from the timing belt cover area. Not good.
<img src="http://66.134.70.69/files/audi/streetwerke/hall%20of%20shame/water%20pump/water%20pump%202/IMG_0540.JPG">
It was so hot it melted it's way into the harmonic balancer backing plate, quite rapidly it appears . . .
<img src="http://66.134.70.69/files/audi/streetwerke/hall%20of%20shame/water%20pump/water%20pump%202/IMG_0542.JPG">
If you break a timing belt at speed you will damage valves, valve guides, pistons, heads and quite possibly turbos and cats.
