Long list of fault codes...
OK, so I just had my Front 02 sensors replaced 2 weeks ago with a set of Zoldman's from VAST, and a week after they were replaced the dreaded CEL returns. I pop the hood a few days back to find that one of my 02 sensors was unplugged (pic below for reference) then I finally had a chance to get it VAG'd lastnight (Thanks to Boston Driver).
<img src="http://pictureposter.audiworld.com/86695/plug.jpg">
Here are the faults...
16711 - Knock Sensor 1 (G61): Signal too Low
P0327 - 35-10 - - - Intermittent
18014 - Rough Road/Engine Torque Signal from ABS: Electrical Malfunction
P1606 - 35-00 - -
16805 - Warm Up Catalyst; Bank 1: Efficiency Below Threshold
P0421 - 35-10 - - - Intermittent
16815 - Warm Up Catalyst; Bank 2: Efficiency Below Threshold
P0431 - 35-10 - - - Intermittent
17746 - Camshaft Position Sensor (G40): Open or Short to Plus
P1338 - 35-10 - - - Intermittent
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 35-10 - - - Intermittent
16687 - Cylinder 3: Misfire Detected
P0303 - 35-10 - - - Intermittent
Could all of these faults be caused by the 02 sensor being unplugged??(except for the ABS) I guess I'll just have to wait and see if they come back, but so far so good as I drove to and from work today and the CEL has not returned (fingers crossed)...
P1606 - 35-00 - -
Jared - didn't you have these codes before the sensor install????
looks like you did per this older post of yours.
also to be clear you only bought front sensors from me. Your cat efficeintcy codes are likely bad (possibly crossed) rear sensors or bad cats.<ul><li><a href="https://forums.audiworld.com/a6/msgs/575568.phtml">old post</a></li></ul>
I get this code all the time...
I'm guessing it's an O2 sensor? I don't know....
I guess I will be taking it to the stealership sometime this week.
