loss of power after 3k? mark from ams said tbb a barometric fault code came up on vag
it seems if i get on the car pretty hard a couple times all of a sudden it seems like the car loses power after 3k like a limp mode but i dont get a code no check engine... If i shut the ignition off and turn it back on if im rolling it will all of a sudden have power again....
this ever happen to anyone?
Do you have access to VAG?
1.You need to see what the codes are.
2.Do a log to see what is going on with the Boost, block 115 and MAF, Block 003 vs RPM in 3rd gear.
You can find more info on the graphing on my site and also you can locate a Vag there too.
To me it sounds like a T-Cut.
just my 2 cent.
Edy
just my 2 cent.
Edy
im waiting on steve I think his name is fixed wing on here, he has the log for the vag we did. I
didnt hear any leaks by the tbb but it wasnt under boost. whats a T cut?
Here is the vag log can anyone help me out with this and let me know whats going on?
VAG-COM Version: Release 504.1-UD
Chassis Type: 8D - Audi A4 B5
Scan: 01 02 03 08 15 17 25 35 45 55 56
Address 01: Engine
Controller: 8D0 907 551 M
Component: 2.7l V6/5VT G 0001
Coding: 06711
Shop #: WSC 06435
7 Faults Found:
16490 - Manifold / Barometric Pressure Sensor (G71) / (F96): Implausible Signal
P0106 - 35-10 - - - Intermittent
18010 - Power Supply Terminal 30: Voltage too Low
P1602 - 35-10 - - - Intermittent
17965 - Charge Pressure Control: Positive Deviation
P1557 - 35-10 - - - Intermittent
17947 - Clutch Pedal Switch (F36): Implausible Signal
P1539 - 35-00 - -
17539 - Oxygen (Lambda) Sensor; B2 S1: Internal Resistance too High
P1131 - 35-10 - - - Intermittent
18062 - Please check DTC Memory of Instrument Cluster
P1654 - 35-10 - - - Intermittent
16891 - Idle Control System RPM: Higher than Expected.
P0507 - 35-10 - - - Intermittent
Readiness: 0000 0000
Address 03: ABS Brakes
Controller: 8D0 907 389 E
Component: ABS/ESP allrad D56
Coding: 04395
Shop #: WSC 06435
No fault code found.
Address 08: Auto HVAC
Controller: 8D0 820 043 Q
Component: A4 KLIMAAUTOMAT D58
Coding: 00160
Shop #: WSC 63351
Skipping Address 15-Airbags
Address 17: Instruments
Controller: 8D0 920 981 BX
Component: B5-KOMBIINSTR. VDO D17
Coding: 02264
Shop #: WSC 08216
1 Fault Found:
01039 - Coolant Temperature Sensor (G2)
30-10 - Open or Short to Plus - Intermittent
Address 35: Centr. Locks
Controller: 8L0 862 257 N
Component: CV-Pump, Alarm, RC D16
Coding: 16140
Shop #: WSC 63351
5 Faults Found:
01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
35-00 - -
01371 - Alarm triggered by Door Contact Switch; Driver's Side
35-00 - -
01374 - Alarm triggered by Terminal 15
35-00 - -
01370 - Alarm triggered by Interior Monitoring
35-00 - -
00956 - Key 2
09-00 - Adaptation Limit Surpassed
Address 45: Inter. Monitor
Controller: 4B0 951 173
Component: Innenraumueberw. D03
Coding: 00102
Shop #: WSC 63351
Address 55: Xenon Range
Controller: 4B0 907 357
Component: LEUCHTWEITEREGLER D004
Coding: 00012
Shop #: WSC 63351
Address 56: Radio
Controller: 8D0 035 195 A
Component: Radio D00
Coding: 00200
Shop #: WSC 63351
End --------------------------------------------------------------------------------------------------
Address 01: Engine
Coding: 06711
Shop #: WSC 06435
7 Faults Found:
P1539 - 35-00 - -
Coding: 04395
Shop #: WSC 06435
Coding: 00160
Shop #: WSC 63351
Coding: 02264
Shop #: WSC 08216
1 Fault Found:
Coding: 16140
Shop #: WSC 63351
5 Faults Found:
35-00 - -
35-00 - -
35-00 - -
35-00 - -
00956 - Key 2
Coding: 00102
Shop #: WSC 63351
Coding: 00012
Shop #: WSC 63351
Address 56: Radio
Coding: 00200
Shop #: WSC 63351
Re: Here is the vag log can anyone help me out with this and let me know whats going on?
You have many codes that don't really relate to each other. I don't think I know enough to help you out, you have an A4 not S4. I would recommend for you to talk to someone who is an export at your car.
A good Audi mechanic is in order. IMO
take a look here
The Audi A4 B5 is what i saw, i still think you need to get your car to a mech. or someone who knows his stuff.
Edy
(from your post)
Edy
(from your post)
Three-twelve
08-04-2007 01:46 PM
PILL PUSHER
10-22-2003 11:38 AM
drhaller
05-23-2000 05:46 AM
