Lowered S4: camber adjustment?
Did audi change the suspension from the A4 when they developed the S4 to allow camber adjustment when the car has been lowered?
My A4, once lowered, had a good bit of negative camber that could not be dialed out. (Wore tires out- but was great fun on ramps). If you lower an S4, does the same problem exist or did Audi provide some abiility to adjust?
thanks-
jim<p>jim gregory
96 A4q Brilliant Yellow
thanks-
jim<p>jim gregory
You can adjust side to side, but not total.
If you run around -1.0 to -1.25, you shouldn't wear out tires TOO quickly. Just go auto-x or track on them once in a while =)
Warren
Warren
With lowered suspension, rear camber cams at (or beyond) limit,
Perhaps we, or some vender, should fabricate replacement cam bolts and washers for the rear with extra "swing"? Shouldn't be hard.<p>Jim De Arras
<a href="http://www.imola.org">2000 00 Imola/Onyx/Alcantera S4</a>
MTM Stage II (Stage III on order)
MTM Full Suspension
MTM/Pagid Brake pads
UUC Short Shifter (original 20%)
Michelin Pilot Sports.
SmartTire Tire Monitor
MTM Full Suspension
YellowS4baby
07-18-2000 05:09 AM
Jim De Arras
23
07-17-2000 05:15 PM
doctorb
07-02-2000 04:38 PM
