Is this a manual boost controler or voltage clamp?
<center><img src="http://pictureposter.audiworld.com/67740/mbc_002.jpg"></center><p>When my car was converted to K04s and a GIAC X-chip the installer connected this little device to some vacuum lines. Is this an MBC or voltage clamp? I removed it just to see what would happen because I'm like that. What risk am I taking?
It looks like Dawes device manual boost controller
I used the same thing on various turbo saabs. I still have one sitting in the garage. It was devised by Gus Mahon, the guy who had his minivan running 12's in the 1/4 mile. I think he had a big IC from a turbodiesel truck on his '89 chrysler van. He had some great turbo info but was killed in a motorcycle accident last year. Click on the link to read about MBC theory and how to adjust it.<ul><li><a href="http://www.dawesdevices.com/boost.html">http://www.dawesdevices.com/boost.html</a></li></ul>
YOU could run into MASSIVE boost spike because the X-chip is meant for KO3's..........
Its meant to keep the boost in check when run paralell to the system. Im assuming you did not do any type of fueling change, or are going the homebrew solution. But you really need to put that back on there. Like i stated GIAC-X is KO3 software. when you request 1bar on KO3 (as the ecu thinks is still in place) is going to produce ALOT more boost with KO4's. You could damge things if not in place with you current setup
elijahallen
10-27-2008 10:48 AM
Neo1130
05-10-2008 06:15 PM
brrman
09-06-2002 09:42 PM
