mbc only on stock chip? will it throw a code?
i dont want to turn up the boost, i just want to keep it at stock levels. i want to install it so its ready for when i throw the chip back in. if it will throw a code ill just wait till i do the chip.
Nope, probably no code. I've run MBC only on stock chip several times (when I had K03s).
The only code I consistently got with stock chip and MBC (only and in parallel) was a MAF too high code, which would trigger the ABS and ESP lights IIRC. This was due to flowing "madd air y0" with all my crazy mods. Piggie and a few others have experienced the same thing when heavily modified on stock chip.
ok thats what i thought
i once saw a pic of the vacuum hose looping back to another side of the n75.
im so excited to hit the strip again im waiting on my DTS to arrive.
what about TCD? when i throw my X in im going to set it at 18psi
i read that you posted that around 6k you would have intermittent throttle cut. should i rig up a tcd? i have some diodes laying around. 4.3 and 4.7 zener's.
