My Boost gauge is showing 6-7PSI with stock ECU, dealer had the car and says nothing is wrong..
car is throwing no codes when I vag'd it Any thoughts?
I do not trust the dealer
AudiWorld Expert
A.) Is it colder now where you are? B.) What pressure does your chip make now?
A.) Colder air may have your ECU lower boost as air is denser and can contain the same oxygen/power with less boost.
B.) If your car was trying to achieve 8-9psi, and only making 6-7psi due to a leak (for instance), it would have to be pretty bad since there is still a lot of overhead that the turbo is capable of working harder to meet that demand. If it can't meet that demand, then the issue is quite intense (unlikely). Therefore, if you were to put it in chip'd mode, you would likely still only see 6-7psi (if you had that major issue). If chip'd mode puts you at ~15psi, then all is likely well, and slightly lower boost may be due to temperature conditions.
Agree on the colder comment. Had my car running in stock mode this past week - only shows between
6-8 psi (depending on temp). I did check block 115 and actual vs. requested appear to be in check.
94LSC
Audi Original "S" Cars
16
05-26-2021 10:49 PM
