My Oil Temperature Gauge is not working - Help!
Old 08-13-2010, 03:59 PM
  #21
hans j's Avatar
Originally Posted by Airbag
Good info for MY 2000 owners like myself .. thanks to the guys on the forum i did not order the sensor that did not work .. I am going to try one thinh however.. any sender should go open then full deflection when grounded... i am going to try this on my car as a test and will update .. may provide for some good troubleshooting info for the future.
Thanks again
It is the sensors. Coincidence I had this problem today on a 02 S6. We had replaced with a cheap Meyle sensor and same thing, no temp until the key was cycled. Besides that I have seen a few aftermarket ones leak, even new.
I couldn't find any way the aftermarket one was changing its signal while testing, and applying voltage or grounding the signal wire didn't effect the gauge. But replaced with a factory unit, works perfect!
Old 12-20-2011, 08:12 AM
  #22
edula's Avatar
Anyone know the name of the part number 8 of the image?
Old 12-20-2011, 08:14 AM
  #23
edula's Avatar
Anyone know the name of the part number 8 of the image and where I buy this part? thanks!!
Old 01-16-2019, 06:21 AM
  #24
mr. winn's Avatar
Hello. I have a 2000 Audi C5 A6 Quattro V6 2.8L, and i have the same exact problem. Just purchased car, no oil leaks, smooth ride, everything. I noticed when car gets warm the temp guage never moves and is staying on the white line reading cold. after reading multiple posts, what do i type in exactly to find the HELLA PART everyone is talking about. I am new to the audi world, and this is my first real car. I want to take the best care of it. I just recently purchased 1. Duralast Oil Pressure Switch (https://www.autozone.com/external-en...58_264928_8537). was this what i needed? If not what is the exact name of part by Hella i should be purchasing? i understand this car has a combined sensor under the oil pan, i cannot find this sensor anywhere online for purchase. Please help Audi experts.
Old 09-21-2019, 05:12 AM
  #25
Andrea Accuracy Gragnato's Avatar
Hello. I replaced yesterday the oil sensor with the HELLA 1J0907660B and it works as it should.
I was receiving an occasional yellow OIL SENSOR message on the dash, and I asked to change the original sensor to my mechanic, together with the oil change. Guess what? The oil temperature sensor on dash was not working anymore with the new aftermarket sensor. So I connected VCDS and there was an error about signal to the oil temp gauge was not compliant or something like that. So I researched here and I found many with this issue. Then I bought the HELLA 1J0907660B and installed and now everything works. So basically the mechanic installed a not 100% compatible sensor. Its reading to the ECU was fine, but not the temp gauge signal.
Old 09-21-2019, 05:14 AM
  #26
I have a 2002 A6 C5 2.5 TDI allroad AKE
Old 09-28-2019, 07:55 PM
  #27
davemark's Avatar
Default Oil temp sensor connector missing
I have no belly pan, and it appears the sensor plug came undone and dragged on the road, and all I have now is some bare wires.
Where is the other end of this wire? Can I just buy the the complete wire?
N_Jay
03-01-2016 02:51 PM
DBS 49
02-09-2013 05:49 PM
S4KTS
12-15-2005 07:09 AM
golfrsi
05-15-2005 09:32 AM
audaciousTT
11-10-2003 07:08 AM
Quick Reply: My Oil Temperature Gauge is not working - Help!
