Is my slipping clutch causing my misfires?...
So my clutch has been slipping for a few months now and when I get on it a little too much it feels like the clutch is slipping and the car stumbles a little the CEL blinks rapidly and when the clutch catches the CEL goes solid. I figured the misfires (checked via ECUX) were caused my the slipping clutch but now I'm not sure. Am i totally off base here?
The RS4 clutch lasted 80K and i'm installing a Southbend STG 3 with stock FW. FWIW
Likely not. If you look at VAG blocks 1, 4, 14 at cold startup, what do you see (example at link)?
http://www.tlcpropmgmt.com/audi/ASP_...RPM_040108.jpg
Bruce
Bruce
Bruce
Bruce
If the misfires only happen during a cold start then you have a timing or air/fuel ratio issue during warm up cycle. While the car is warming up it does not use its o2 sensors, it uses a pre determined fuel map until the exhaust and everything is at operating temperature.
Besides that I would just double check spark plugs and ignition wire connections. Use the correct temperature rated spark plugs for your car.
Evil Buddha
RS4 (B7 Platform) Discussion
07-05-2006 08:15 AM
audi/s/scott
12-27-2005 01:48 PM
nickelmedia
11-05-2005 06:32 PM
