Need some suggestions......(more)
<center><img src="http://pictureposter.audiworld.com/9056/scan18.jpg"></center><p>I found that after my suspension mod (H&R race with adjustable koni)the car still roll a bit on the track. Do you guys think I should adjust the stiffness of the shocks or buy a rear anti-sway bar?
Why did you put the X though the VW...lame man *sigh* some people I demand that you
go out pop your hood and with a razor knife put an X though every VW logo you find in there...see you in about...ohh a thousand years or so...have fun.
Regards,
James R.
Regards,
James R.
Shocks can't cure lean (they just damp MOTION). (more)
Only stiffer springs and/or stiffer sway bars can decrease it (you seem to be lowered enough already). Even so, there'll always be some lean.
If you car is neutral now you could put stiffer sway bars front and rear to avoid introducing over/understeer. If it still pushes now, a 19 mm rear bar would be fine. To use 22 mm in rear would also require a stiffer bar in front. I haven't been able to locate a stiffer front sway bar for my 2001 Avant, though.
Do I need to upgrade front sway bar, now that I will have haldex Performance unit and 19mm rear sway
ItsJ
11
03-12-2006 06:49 PM
markv
12
02-04-2003 05:55 AM
Bucket
05-13-2001 12:16 PM
