Neuspeed Sway Bar questions. Are ther 22mm and 19mm versions, do they crack the sub frame?...
After doing a search, I have the following questions...
1) Are there 22mm and 19mm versions?
2) Are they adjustable?
3) Do I have to worry about cracking the subframe?
4) Where is the best place (least expensive) to purchase?
I have 19mm on hard setting/ good mod for the money...
1&2- Yes
3- Their new enforcement for the subframe eliminates the cracking issues [hopefully!]. I have mine on for a month with the latest version of the bracket and so far so good.
4- Cheapest place I found at was www.bostonaudituning.com but I had to wait few weeks
I take it the part number was 25.02.19.4 , but...
1) Did it come with sub-frame reinforcement brackets?
2) I see partnumber 25.02.22.4, which is 22mm, is that overkill for a non-track driver?
Yes, it comes with the subframe brackets
Same part# you buy anywhere else. Mine is on soft setting. So for me, 22mm would be overkill. I have heard it tends to kick in a lot of oversteer with a bigger rear bar alone.
No prob with the 22mm on hard for over 40k miles between 2 cars.
the first had no reinforment brackets (25k miles) and the second didn't for a few K miles(20k total so far). Never a problem. I track and autox.
those are so HARD that they don't ONLY crack subframe, they crack the engine block, too~ ;-)
hey, don't you question me or think i'm kidding...
i'm sure some service will tell you that your warranty's void'd because .... as I said... LOL
Bikingman
06-17-2002 12:06 PM
mooman
02-06-2002 07:09 AM
mattchow
10-16-2001 06:31 AM
