Oddness after Brake install? Mintex Red Q
Ok, I snagged AWE's OEM sized brake upgrade kit. Because I just don't have any time anymore, I had the local Audi/VW shop do the install. For those that have had This kit and/or Mintex Reds, Does it take a while for these to bed in? Right out of the parking lot driving easy, I thought I was going to run a red... the pedal sank a bit further than I anticipated. I could feel some friction on the brakes, but not much stopping power. just after the red, I had the chance to give it some speed, then eased onto the brakes harder and harder. Got some smoke for a few seconds too... The pedal still sank lower than with the stock setup. The mech. says it';ll take time for the brakes to bed-in/adjust themselves. But the lack of stopping power initially scares the s--t outta me. My Hawk HPS/OEM Brembo setp on my old Si, was much safer on the 1st drive, not to mention after the bed-in process.
SO, long story short, am I paranoid? Or is this normal?
Thanks in advance, and as usual, you guys rock!
-Nate
-Nate
You said, "I snagged AWE's OEM sized brake upgrade kit"
What does this kit consist of? You say it's the same size, so I don't see how the rotors would be an upgrade unless they solve the warping problem. The pads are a difinite downgrade. I'd attribute the inferior performance to the pads.
They don't bed themselves - you have to do it.
STFA for proper bedding procedure and go do it. After they recover, the pads should work better. If they don't you either have a problem, or that setup/pad sucks.
FWIW, my Hawk HPS need to be re-bedded every now and then.
Pelican18TQA4
04-10-2001 06:18 AM
PGTT
12
03-27-2001 11:26 AM
