Oil blow-by around breather hose... problem??
<center><img src="http://pictureposter.audiworld.com/21756/breather.jpg"></center><p>I just replaced my BPVs (they're a couple years old) and noticed a lot of residue around the breather connector.
Why would this be happening, and does it look like a problem?
Probably a cracked or dried o-ring.
Pull off that hose and you'll see that there's an o-ring on the plastic coupler . . . No reason why you can't just pull the old one off and slap on a fresh one.
Dave
Dave
Thanks! Is this blow-by likely to be causing some of my problems?
periodically:
mixture too lean DTC
evap emissions purge valve incorrect flow
I can't get my catalyst readiness code to set
umm...make sure your 3 way check valve is installed in teh correct orientation
its the one that likes to crack after a while. pretty sure this could be your problem. you will end up dumping boost pressure into your evap system.
In my experience it is not unusual to get some buildup in that area, that
looks excessive. Could replace the o-ring. I would do what other had suggested. Wipe it clean and keep an eye on it.
