Oil leak photos - not positive of source...
AudiWorld Expert
The day before the turkey, I changed my oil and took some pics of the leaking. Not sure if it's the RMS, upper oil pan, lower oil pan, or some combo of all three. I guess I'll be pulling the engine sometime this spring to find out.
<img src="http://ctny.audiworld.com/mark/s4/maintenance/oil_leak/files/images/DSC04784.jpg">
<img src="http://ctny.audiworld.com/mark/s4/maintenance/oil_leak/files/images/DSC04785.jpg">
<img src="http://ctny.audiworld.com/mark/s4/maintenance/oil_leak/files/images/DSC04786.jpg">
<img src="http://ctny.audiworld.com/mark/s4/maintenance/oil_leak/files/images/DSC04787.jpg">
<img src="http://ctny.audiworld.com/mark/s4/maintenance/oil_leak/files/images/DSC04788.jpg">
<img src="http://ctny.audiworld.com/mark/s4/maintenance/oil_leak/files/images/DSC04789.jpg">
<img src="http://ctny.audiworld.com/mark/s4/maintenance/oil_leak/files/images/DSC04790.jpg">
<img src="http://ctny.audiworld.com/mark/s4/maintenance/oil_leak/files/images/DSC04791.jpg">
prior post:<ul><li><a href="https://forums.audiworld.com/s4/msgs/2615747.phtml">https://forums.audiworld.com/s4/msgs/2615747.phtml</a</li></ul>
when my RMS went at like 20k miles, it was ONLY on the lowest part of the trans case...
I also now have about 1/5 of the amount you have on your lower pan and parts up front, it looks identical, just not as severe. There isn't a single drip on the trans housing. So, I'm guessing you have two seepage points, RMS and upper or lower oil pan.
You coming to Road ATL???
AudiWorld Expert
I did those not to long ago....
<a href="http://ctny.audiworld.com/mark/s4/maintenance/engine_pull/" target="_blank">Pass side, 143k</a>
<a href="http://ctny.audiworld.com/mark/s4/maintenance/head_drivers_side" target="_blank">Driver side, 153k</a>
now at 163k
now at 163k
