OK, assuming clutch is toast, which new clutch for Stage2 and how much will it cost incl install?
There is no puddle of fluid under the car so I'm assuming the clutch is fried as you all are suggesting.
Which clutch should I get then? Does the RS4 offer the same kind of daily driveability that stock does?
And what's it going to run me roughly for the clutch and install?
Sigh...
Sigh...
new aluminum flywheel better than stock/resurface
For 2.7T owners looking for lightning fast throttle response and engine spool up, add our lightweight flywheel. This aluminum flywheel weighs in 13.6 lbs lighter than the stock unit (13.4lbs) and comes complete with a factory pilot bearing and all mounting hardware. Less rotating mass means liberated engine power.
awe.com
awe.com
