Ok guys I need help,I want to change the Display Language to German,via VAG or otherwise,any FAQ's.
I got a post the other day, but this will not work with the VAG.com software, any specific instructions to change this, or other tricks to changing it without using a VAG-Tool.
Thanks.
<img SRC="http://pictureposter.audiworld.com/7684/pdxa4boost.jpg">
Pic just to get your interest
Thanks.
Just checked Bentley manual page 01-42
Do this at your own risk, I haven't tried it.
It appears that you go into the instrument cluster module, select "Adaptation", and change channel 4 to a value of 1. Or it may be that you change the softcoding via the recode option.
Viel Glueck!
From Bentley
<b>
Notes:
The display shows only the last digit of the five-digit language code, e.g. 1 for German.
Input of incorrect values will end the adaptation function. "Adaptation" function 10 must be selected again.
</b>
Viel Glueck!
From Bentley
<b>
Notes:
</b>
lvl10shaman
11
03-15-2010 12:03 PM
Pinball
VAG-COM Discussion
03-22-2004 01:04 PM
PDXA4
04-27-2002 08:46 PM
PDXA4
04-24-2002 01:17 PM
CrazyINP-12V Ivan
10-09-2001 12:37 PM
