OK, My MAF is dead. I need options people.
What is my least expensive option. I have a 2000 A6 2.7T. The part # is 078-906-461B. I tried cleaning it, but no luck. Anyone know if an RS4 MAF will work. I've seen those on ebay. Aside from K04s and Giac X chip, the airbox, etc. is stock. Thanks
Are you running a boost controller? Did you turn down the boost at all? Still on stock injectors,
right?
You should switch to the giac m-box code and put an hitachi maf on it. Then, you won't be going through maf sensors every month. Email mike01s4 at yahoo dot com, he should be able to help you with everything you need.
