Paging Dr.Duct_Mossburg
I have a couple questions about the dash. I have a really annoying squeak on the driver's side when i turn left or right, and was wondering if you saw anything in there that i might be able to tighten up. I took the gauge cluster out, but i didn't see anything. I've looked for write-ups also, can you give me a link to the most helpful one?
any help would be greatly appreciated
Miles
Miles
i dont think so. if i put pressure on the dash toward the windshield, or if i push up or pull down
on that lip thats over the gauges, it doesn't squeak. I'll check though, thanks for the input.
If its at a certain spot when you turn its prob your.....
U joint linkage thing under the dash. Get some white lithium grease and spray that sucka see if it helps...it took me a couple times and rotations in between to really grease mine silent.
This is pretty obvious when it is the linkage....If its at speed and over bumps when turning
It sounds like something rubbing under load like youre thinkin. Good luck. I still need to do something about my glove box and pass. B pillar.
Theirs not really to much. The dash is simply a pad covering it.
I cant think of anything in or under the dash that would cause that.
maybe the air duct plastic rubbing against the plastic shell of the pad ??? is the dash tight ?? What kind of a squeeking is it ??
Maybe take a vid.
None of the right ups were to great. They were nice write ups, but simply didnt state all of the little small things. Theirs alot of time involved in removing it and putting it back in.
Maybe take a vid.
Allroady DungBeetle
06-02-2006 04:15 AM
blackfnTTruck
12-29-2004 06:02 PM
