Piggie Pipes - with No O2 reposition
Old 01-20-2006, 08:33 PM
eurotall's Avatar
Default Piggie Pipes - with No O2 reposition
Has anyone used a diode or resistor (whichever is needed) to trick the ECU from throwing CEL after gutting both DP's intoPiggiePipes ?
...instead of relocating the O2 sensors with drilling and welding bungs after the Cat.
I did STFA but nothing....cant find any posts on taking this route versus Relocating O2 sensors after the Cat....((several posts on Relocation))
TIA
Old 01-20-2006, 08:34 PM
kiNGMak.:.OEM's Avatar
buy some spark plug non foulers.. do a search...
Old 01-20-2006, 08:38 PM
B5QShip's Avatar
as kiNGMak said, spark plug non-foulers. Also search for LanceEagle's post on O2 Simulator Solution
Old 01-20-2006, 09:06 PM
eurotall's Avatar
Found Keman's o2 Simulator mod not Lance Eagle's...Non-foulers seem to all be in the A4 forum not S4
Old 01-20-2006, 09:13 PM
B5QShip's Avatar
Default I know for a fact that "mbox" and "Snow Trooper is Numb" have done the non-foulers
look in Edy Jun's S4 directory, and you should find the 02 simulator post catalogued there.
Old 01-20-2006, 09:30 PM
LanceEagle's Avatar
If your interested, see sig
Old 01-21-2006, 09:47 AM
mbox's Avatar
Default yep, got 'em in as we speak and never once had a problem.
sadly, it's probably the only mod I've done that's worked flawlessly.
Old 01-21-2006, 11:00 AM
B5QShip's Avatar
Default lol, hows the S3 tweakin' and tunin' coming....
I'll more than likely be using the same fueling setup as you, so I'm curious what kind of luck you have with it...
Old 01-21-2006, 02:45 PM
mbox's Avatar
Default I forgot to update my sig but I've turned to greentops w/ a modded airbox.
The Delphi's throw too much fuel for my taste. I could never get my part throttle fuel trims < 10% even if I pulled 25% primary.
Honestly, this is not an area you want to go against the grain with. Go with a modded airbox and greentops like most the homebrewers. You will be a lot happier if you run into any problems that need working out. I'm learning this issue the hardway.
The tweakin' and tunin' is coming along very slowly. I recently just pressure tested my car and found 3 small boost leaks and think my cat may be bad but b/c of my own 02 mod, I won't throw a cat code so the only way to tell is a visual. I'll get through this eventually goddammit.
Osmosis
10
11-20-2016 09:35 PM
adminisTerTurbo
10
04-08-2008 12:43 PM
JoemommaS4
13
08-08-2006 11:39 AM
DenverAvant
04-14-2005 04:27 AM
zain
05-15-2000 01:48 PM
Quick Reply: Piggie Pipes - with No O2 reposition
