Piggified my DPs Saturday. Best mod for the money.
I spent my Saturday removing my down pipes, piggifying and reinstalling them. Piggy Pipes (cheap Chinese knock-offs) are the best bang for the buck you can do to a S4. I have the cost of O2 sensor bungs($5) and a Saturday worth of time invested in them.
There are few HP gains that can be had for such a small price. The aggravation of removing the top DP bolt on the driver side DP is another story. I was worried about piggifying the DPs not removing them, what a PITA. My hat's off to those of you who have done the job on the ground. I wouldn't even attempt it without a lift.
I really don't know what the HP difference is, but what I can say for sure is it helped the turbos spool up quicker. The power comes on about 500rpms lower than before the piggies. It is a great mod if you have the tools and lift at your disposal.
I think the easiest is to use a hole saw (1.25") and drill through the
center of the cat. Then punch it out in three sections with a large screw driver. You can leverage and tear most of it out that way pretty quickly. Then just use a flapper or wire wheel on an extension to clean up the bits and pieces left on the walls.
ymmv.
ymmv.
