Was planning on running seafoam through the car today.. questions inside
Old 02-09-2005, 11:59 AM
New Member
lithium15's Avatar
Default Was planning on running seafoam through the car today.. questions inside
Do i put the sea foam through where i have my boost gauge and on which side of the T fitting. The side leading to the gauge or actully "cut" the line in half? and run it though the left side towards passanger or right towards driver? and once your ready to drive the car do you put back togeather the line? or leave it broken?
Old 02-09-2005, 12:05 PM
RKA
AudiWorld Uber User
RKA's Avatar
boost gauge is tapped into the FPR line?
Old 02-09-2005, 12:08 PM
Audiworld Sponsor
DAP@EPL's Avatar
Default I removed my boost gauge hose and used another peice of hose on that end of the T-fitting...
Sucked the seafoam out of a paper cup.
-Dave Pramanik
Old 02-09-2005, 12:09 PM
Elder Member
2000s4biturbo::Uli's Avatar
yes, the vacuum line.
Old 02-09-2005, 12:11 PM
Elder Member
Default so it sucked it through the vacuum line?
weird. how was it? my buddy used this 2 weeks ago in his integra. is it worth doing?
New Member
lithium15's Avatar
So after sucking up Seafoam. do you reconnect boost gauge or let seafoam where out after WOT?
Old 02-09-2005, 12:13 PM
Audiworld Sponsor
DAP@EPL's Avatar
Default Yup. Got a lot of smoke so I assume it did something.
Didn't feel much of a difference but I guess cleaning the cylinders once in a while can't be bad.
-Dave Pramanik
Old 02-09-2005, 12:14 PM
Audiworld Sponsor
DAP@EPL's Avatar
Default I reconnected the boost gauge and let it sit for 15 minutes or so.
Then I went out and did some WOT.
-Dave Pramanik
New Member
lithium15's Avatar
do you reconnect boost gauge immidealtly or let seafoam where out after WOT?
Old 02-09-2005, 12:16 PM
Audiworld Sponsor
DAP@EPL's Avatar
Reconnected the boost gauge. The seafoam will vaporize as it goes through the engine.
Quick Reply: Was planning on running seafoam through the car today.. questions inside
