problems shifting into 1st and 2nd........
i got a neuspeed shifter and i think i used to much force on one of smy rows now i have to use extream force to get it into 1st & 2nd. 3rd and up are pretty unaffected.. anyone know whats wrong?
Re: first check to see if you just didn't install the SS poorly
yea thats what i think im gonna end up doing.. but if i dont can you give me a good link that shows how to take out the ss.
Bentley guide has a good section on adjusting the shifter
When installing a SS, it is easy to adjust the lever to be too vertical in neutral and mess up engagement in first and second. Do you have the same play side to side when in 2nd and 6th? If not, you need to align things side to side.
Also, there is a very specific distance for the shifter mechanism to sit back from the front of the opening in the console.
Try these links...
<a href="https://forums.audiworld.com/s4/msgs/871929.phtml">First Link</a>
<a href="https://forums.audiworld.com/s4/msgs/479810.phtml">Second Link</a>
I just installed my shifter this weekend and these helped me a lot, especially the pictures showing the correct orientation of the shift lever when in neutral (leans to the right 3 deg, and back about 7 deg). If your shifter is sitting straight up and down in neutral, you are not aligned correctly.
Try these links...
r.e. first bolt
Loosen the 6mm hex bolt and the entire shifter assembly slides fore and aft on the rails. Moving the assembly back causes the shifter to lean more forward, and vice versa.
I AM 2ks4
11-25-2006 06:24 PM
MachtigAvant (v3.0)
18
12-16-2002 11:08 AM
WYSIWYG
03-27-2001 06:30 AM
