Question for BBS LM (18 x 8.5 et 30) owners - What is your ride height (more)
<center><img src="http://pictureposter.audiworld.com/16459/dsc00051.jpg"></center><p>I had the wheels on my car with stock suspension and had no rubbing issues. However, I'll be installing custom coilovers with 600/700 spring rates and would like to know the optimal ride height (ground to center of fender, e.g., 25.5 inches)that will not require fender rolling. Tires are 225/40 Toyo T1S.
TIA. |
Re: Question for BBS LM (18 x 8.5 et 30) owners - What is your ride height (more)
18" should be ok, I don't think you have to roll your fenders unless the car is really slammed.
Careful! I ended up not getting them due to rubbing issues with H&R streets
I didn't want to roll my fenders. and put spacers on.
It's my fave wheel, but just not "properly" fitted for the S4. IMHO |
audio...check Sander's Site: there are details for the rides posted
maybe they will help you learn more...<ul><li><a href="http://www.sanders-stuff.com">http://www.sanders-stuff.com</a</li></ul>
You won't rub at maximum height on H&R street coilovers (m)
you could probably go as low as 26" with H&Rs. I'm hoping to be able to go as low as 25.5 with higher spring rates.
et30
Do you think/know if RXII's would rub?
I'm getting the H&R streets so now would be a good time to ask! :)
your car looks nice man!
I keep liking those wheels more and more ;)
thanks but the only LMs there were 19" (et 32)
RXIIs have a less aggressive offset @ et32, just like 19" LMs -- less likely to rub than 18" LMs
