Question for nyet about ECUxPlot, should the calc HP and calc torque be close with a TIP, as long as
Old 12-07-2008, 06:06 PM
Paracaidista2.7T's Avatar
Default Question for nyet about ECUxPlot, should the calc HP and calc torque be close with a TIP, as long as
the RPM/MPH are right? I used the TIP gear ratios and tire circumference (from tire rack) as well as using the frontal area and weight of the car published on carfolio.com, but my numbers seem too high.
Old 12-07-2008, 07:51 PM
AudiWorld Expert
nyet's Avatar
yea, it should be close
Old 12-08-2008, 12:24 AM
Cool. Thanks.
Old 12-25-2011, 01:43 PM
vtraudt's Avatar
Default How is HP calculated in ECUxPlot?
How is HP calculated?
Is the shown HP considered cHP or wHP?
What unit is the torque shown? Nm (as in the ECU data) or lbxft?
Old 12-27-2011, 10:41 PM
choptt's Avatar
by tq. throttle position maf boost coolant 02 sensors. also your ait temp effects all of those..
best way to tune your car is to drop 32 into the tip for sport mode,
next swap out n75 for a smaller audi tt 225 n75. then when you want max power to play with just unplug the maf and turn the n75 scew cc 1/4 turn. mark the n75 for reference.
pretty much leave everything else alone.
ive got a 2.7t 5sp tip 1bar file if you want.
Old 12-28-2011, 04:44 AM
vtraudt's Avatar
Default ECUxPlot HP numbers
So that mystery number is supposed to reflect cHP or wHP or awHP?
Has anyone logged a Mustang Dyno run with ECUx and have a rough idea as to how well the ECUxPlot numbers simulate reality?
Trug
Audi allroad
03-13-2003 04:10 AM
VikingDiesel
06-08-2002 07:56 AM
Sony King
01-25-2001 10:46 AM
timcar
12-13-2000 11:54 AM
Steve Schmidt
07-18-1999 07:43 PM
Quick Reply: Question for nyet about ECUxPlot, should the calc HP and calc torque be close with a TIP, as long as
