relocating 02 sensors on piggy pipes?
This just came up somewhere...
I am going to do this instead of relocating the O2s... If I am reading it correctly.<ul><li><a href="https://forums.audiworld.com/midatlantic/msgs/119216.phtml">https://forums.audiworld.com/midatlantic/msgs/119216.phtml</a</li></ul>
? for you... if i get a CEL with non-foulers will moving the bungs
after the cat make the CEL go away or will i need to clear codes with a VAG? im asking becasue i dont have a VAG-COM and i dont want to be driving arround with a stupid CEL if i decide to do non-foulers and they dont work. if i will need to clear codes i'll just play it safe and relocate the O2 bungs. TIA
Well, I've never thrown that code, but its just a code.
<center><img src="https://www.audiworld.com/tech/pics/eng75_Bungfitting1.jpg"></center><p>If you clear it, and solve the issue that caused it, it should not return. Many people have VAG-coms and there is actually a list of people who have it. Search the archive for VAG list and see what comes up. You'll be able to find someone in your area to help you out.
If you can drill and weld, relocating the bungs is not that big a deal. You just need to put them in the correct place so they don't interfere with anything and the wires will reach once the pipes are back in. Check out my piggie pipe write up in the AW tech section. There are others out there too.<ul><li><a href="https://www.audiworld.com/tech/eng75.shtml">https://www.audiworld.com/tech/eng75.shtml</a</li></ul>
joe@vwvortex
16
01-05-2009 02:32 PM
apb_s4
03-09-2006 05:03 PM
Howie Feltersnatch
01-13-2004 12:00 PM
Phil type 951
02-06-2003 06:44 AM
blk18tq
04-05-2002 08:54 AM
