In response to K04 turbo reliability versus K03 - AudiWorld Forums
Go Back  AudiWorld Forums > Audi Models > Audi S4 / RS4 > S4 / RS4 (B5 Platform) Discussion
Reload this Page >
Sponsored by:
Sponsored by:
Old 08-04-2002, 02:01 PM
Default In response to K04 turbo reliability versus K03
You've got to realize that the K03s are still well known to take a dump when only run at stock boost levels which is only about .6 to .7 bar.
The stock RS4 runs more boost than that.
I would venture to bet that every single person here in the US that has switched to K04s will be running higher levels of boost than the stock K03 original figure.
If you want to make things even, talk to someone that has switched to K04s into lowering their boost to stock S4 boost for a year or two and then look at the results....I don't think that you will find anyone willing to do that....because why have they switched if it wasn't to gain higher horsepower...and they are going to be running at least .8 bar or greater. We have raced with K04s for two years and we run consistently with 1.2-1.4 bar and have NEVER had a K04 problem....
Don Istook
donistook is offline
Old 08-04-2002, 02:06 PM
Elder Member
Curious.. what oil do you use also.. TIA
Bryce is offline
Old 08-04-2002, 02:08 PM
Member
Out of curiosity, how do you guys let the turbos cool after a race?
Jeremy Clarkson is offline
Old 08-04-2002, 02:28 PM
AudiWorld Expert
I do believe Don mentioned that they have a manually operated cooling fan thingamabob.
jyoteen is offline
Old 08-04-2002, 03:15 PM
Member
a thingamabob huh? where can I buy on of those?
poopeter-el sigthief is offline
Old 08-04-2002, 03:18 PM
I sell you one
DanosS4 is offline
Old 08-04-2002, 03:54 PM
We just let the coolant pump run for about 3-4 minutes
Old 08-04-2002, 03:55 PM
Royal Purple Racing Oil-Racing 21 (about 10W30)
Old 08-04-2002, 04:22 PM
Senior Member
Default Did you attach a seperate switch to the coolant pump?
Stock afterrun coolant pump correct? Thanks.
Kent L is offline
Old 08-04-2002, 04:49 PM
Yes...we just put in a toggle switch with direct 12V...very simple
Quick Reply: In response to K04 turbo reliability versus K03
© 2018 MH Sub I, LLC dba Internet Brands
